Old 08-05-2007, 06:00 AM   #1
ml68nova
ml68nova's Avatar
Determining a stuck fuel sender from outside the truck
A quick question and maybe a stupid one as well,
I have a 72 c30 dually wrecker and my gauge is staying a 1/4 tank but moves at 1/16 either way when using or filling the tank. It just happend last week while towing my car.
I supect the float is stuck or heavy (has a crack) But I would like to check it before taking out the seat (solid will not fold) and yada yada.
Has anyone used a rod through the filler neck to move the float? I noticed from pictures ,the sender is located more to the passenger side possablly making this idea a mute point.
Thanks,Mark
ml68nova is offline   Reply With Quote
Old 08-05-2007, 07:27 AM   #2
see ten
WTB this ad
see ten's Avatar
Re: Deteriming a stuck fuel sender from outside the truck
Mine did exactly the same thing for a couple days and then suddenly started working again. I suspect a sending unit is in my future . The filler goes in at an angle so it's going to be difficult to run anything straight through it. I would think a good sturdy coat hanger might be able to be used to bump the float? Who knows? Keep us updated!
see ten is offline   Reply With Quote
Old 08-05-2007, 09:03 AM   #3
Premium72
Premium72's Avatar
pulling the seat isnt that hard of a job, i would just take it out and pull the sending unit. its 8 bolts. good luck.
Premium72 is offline   Reply With Quote
Old 08-05-2007, 12:09 PM   #4
mbgmike
Re: Determining a stuck fuel sender from outside the truck
You can put a Rheostat and Ohm meter on it and verify if its the sender. Senders don't cost a whole lot. Generally run from $25.00 to $30.00.
mbgmike is offline   Reply With Quote
Old 08-05-2007, 08:09 PM   #5
72hotrod
72hotrod's Avatar
I changed my sender with the seat full forward.
72hotrod is offline   Reply With Quote
Old 08-05-2007, 09:35 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
to check the guage pull the tan wire at the tank and ground it out. Your gauge should go to full or over full tank when grounded. If it doesn't move it is the gauge or the wire.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
