Big Block and Firewall Clearance
Anyone have any issues when putting in a big block and having clearance issues with the firewall? I have a 350 in right now, and with the HEI its super close.
For a big block do you have to cut out the firewall to create more room for the distributor? thanks
1930 Olds 5 Window Coupe 1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350 1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!" 1966 Toronado 1971 Cutlass 1972 442 1978 Chevy 1/2 Long Fleetside 2001 Dodge 2500 |
Re: Big Block and Firewall Clearance
i put the HEI in mine too and it is very close. the two back plug wires touch the firewall.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Most likely both of you guys have your small blocks mounted in the 6cyl position. I remember going to a car show and a guy had a big block in his 65 and the dist looked like it had about two fingered width before touching the firewall.
2003 Chevrolet CCSB 4x4 1500HD Mine 2011 Toyota Corolla S Wife's new ride 2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014 1990 Chevrolet 454SS GONE 02/26/11 ![]() 1991 S10 SCSB GONE 12/24/08 ![]() 1965 Chevrolet LB GONE 06/06/05 GM for life ![]() |
well i just pulled my engine so ill check it out and see before it goes back in.
#5 | |
![]() So i am kinda wondering if i use the 73-87 crossmembers that already have the 454 if the clear to the firewall will be an issue..
no problems with mine just cant use tall rocker covers,everything clears
Harry, thanks for the info and pics!!! WHat kind of headers are you using there?
thx ![]()
i have what they call a "budget" heater in my truck which is mounted under the dash on the firewall and it only has a fan and demist,interior control. No hot or cold control !!
oops didnt read your question properly,the headers were made at a local exhaust shop in my town and i think i have some pics
Harry, so did you use the stock mounts for the engine? thx
yep,i used the 63 engine mounts off the smallblock when i removed it and bolted them to the BB and it slotted right in.
Right on you've got a great ride there. Looks like you're using HEI too, right?
#13 |
yep used the hei dizzy out of the smallblock as well
#14 |
Wow thats some tight header clearance. I hope your motor mounts don't have any flex in them.
#15 |
been driving it around and theres not one part of the exhaust or headers hitting anywhere and i put that down to the mounts on the bellhousing(original) and engine not letting to much movement happen.I have a really lumpy cam in her as well.
#16 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
When I built my '66 Burb with a 454, I wanted to be able to run taller valve covers. So I just moved the engine and trans forward ~2" and fabbed up some custom motor mount brackets. Wasn't too hard to do....had to drill new trans x-member holes anyway with the T400. Also I was still able to use '73-'87 headers.....they wouldn't work if you kept the 4spd though.
#17 |
heres my 454 with custom motor mount brackets ,full length hedmen headers
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
#18 |
since my 350 has a serious rod knock going on Ive been on the prowl for a replacement motor. Found a killer deal on a 454/th400 combo out of a wrecked 80's pick up. I just might be joining the big block crew!
#19 |
![]() Join Date: Sep 2006
Harry has a 63 and for some reason I think the firewall is differnt then a 65. I could not get my bb to sit back in the orignal holes without cutting the firewall for clearance. Also when getting headers that are not custom made the left stock perch is in the way ( on my truck anyway) I will be updating my thread soon when I get the mounts I ordered and will let you guys know what is going on. http://67-72chevytrucks.com/vboard/s...d.php?t=259536
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#20 |
Ok, so could someone lay out straight what all needs to be done or what issues are definete with using stock mounts? It seems that most of you are either using different mounts or repositioning the perch locations. Also seems that 60-63' are different that the 64-66' when it comes to this swap as well. From all of the threads Ive read, just seems that header clearance is the main issue here....but that using a smaller primary would fix this problem. Got a sweet deal on a motor but just dont have the time or $$$ to guess around at how to get that big sucker into my ride.
#21 |
Hey guys,
I am putting a 327 in my 66. It originally came with a 6 and someone swapped the 6 for a 305. They mounted it in the wrong position so the distributor was close to the fire wall. If you look at the frame on each side you will see a series of 3 evenly spaced holes. The back two are for the 6, and the front two are for the 8. Just for any one who cares. Later wirebiter |
#22 |
Aye I just noticed something, almost all of you are running full length headers, do you think the manifold clearance will be an issue with a set of mids/shorties?
#23 | |
Shorty headers might work on the BB but i have not idea on that. I want full lenth headers.. And they are 1 3/4 primary tubes not the 2"
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 12-02-2007 at 07:37 PM. |
#24 |
Resistance is Futile
Hey guys, as wirebiter stated...use the front holes. I did this with minor elongation of the mount holes to keep the spacing correct with the old style engine mount. With the small block in you could lose a 6-pack of beer behind the distributor.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#25 |
i got mine fitted finally.. I used the motormouts on this page. The ones in the middle of the page on the bottom.. http://www.truckandcarshop.com/trucks60_72/t60_097.html This was so I could set the engine back as far as I could. If you move it forward you can just use the later mounts but I thought they were to ugly for me.. I look at ugly in the mirror I don't want to see it in my truck...
