Removing control arms on 67
I have the spindle out and the control arms hanging . What holds the upper and lower arms on. Been chiping away at 40 years of grease and gunk. Are these held on by u joints or bolts, or a combination. Kinda hard to tell with all that gunk. Thanks
#2 | |
Re: Removing control arms on 67
Lowers are held on by 2 u-bolts; one on each end of the a-arm shaft. The u-bolt nuts are accessed from the top side of the engine compartment crossmember.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-05-2007 at 12:49 PM. |
Thanks Scoti. Got the drivers side off today.
