Old 08-05-2007, 11:16 AM   #1
The Intimidator
The Intimidator's Avatar
87 14 bs/f swap
I have got the new axle The gears are the same and breaks should be fine for a couple more months much better then the metal on metal breaks on the truck now. I was wondering what I need to change modify or break to get this new axle on it came from a 90 half ton chevy 4x4. I was also wondering if the leafsprings from the 90 will fit on the 87 they are a heavy leaf pack vs the stock half ton on the 87 should make the truck sit nice and level with a load of rock in the bed or a trailer hitched up.
The things I can see being a problem with this swap is,
The u-joint will I need a conversion unit?
Driveshaft length will my stock one be long enough or short enough to clear the new axle?
Spring perches will these need to be moved if so not a big deal but how do I line them both up and keep proper pinion angle while doing it?
Thanks my plan is to eventually (when money permit's) run 4.56 gears a detroit rear and a arb type locker up front with some other mod's to hopefully stand up to 35" super swampers which I hope the ten bolt front will be able to survive
87 k1500 rcsb
4 inch lift 33/12.50/15 bfg a/t's
soon to be 350/350/205 with a 14bs/f built 10 bolt front and 35" super swampers
The Intimidator is offline   Reply With Quote
