Old 09-24-2002, 06:02 PM   #1
LT-102
Dana 60 Questions
I've got a line on a Dana 60 posi, but I don't know if it will fit. By fit I mean will the mounting of the leaf springs and shocks line up the same. I have a 71' C20 with a Dana 60, the one I'm dealing on is out of a 79' Ford. The axle is 300 miles away so I can't just drive down the street and lok at it. I know the spline count may vary, but what other differences are there? THanks
LT-102 is offline   Reply With Quote
Old 09-24-2002, 06:13 PM   #2
Mike C
Mike C's Avatar
After the mid 60's almost all of the Danas are the fine spline, but like you said, you never know! One or the other might work, but I doubt it. Fords also typically have a lot longer floating hub assembly and require different wheel center caps than a GM. Get the Ford 60, sell it to a guy with a Ford, and then get one for a 67-72.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
