Junior Member
![]() Join Date: Dec 2006
HEI wiring question-will this work?
My son and I installed an ACCEL HEI unit yesterday with new wires and plugs. Have it all set up except the 12 volt wire to the distributor. I know we have to change the old resistor wire. Can we connect a 12 guage wire to a small piece of the old wire at the firewall or do we have to run the new wire from the fuse block? We appreciate your help.
'63 C10 lwb flatbed '66 C10 lwb stepside '68 C10 lwb stepside (parts) '68 C10 lwb fleetside (17 yr old son's ongoing project) '03 HUMMER H2 (wife's) '06 3500 flatbed liftgate (My work truck) |
![]() Join Date: Mar 2003
Re: HEI wiring question-will this work?
It's better to completely eliminate the resister wire and go direct.
![]() get rid of the resistor
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
I recommend an inline fuse also. Dont take a chance losing your truck over a $1 fuse...
what i've always done is trace the resistor wire back thu the harness to the firewall pulled the connector out of the firewall mounted terminal block and used that for my feed (correct terminals available at napa)then i've rewrapped the harness that goes accross the firewall for a nice clean factory looking job with no addon wires and no excess dangling wires
Another really easy process is just to take a 12G wire with a female spade on it and connect to the IGN UNFD connector on the fuse box, route it out through the firewall with the rest of the wires, across the wire channel at the top of the firewall and right down into the distributor. Nice, clean and easy.
Run a 16G green wire at the same time for your future tach ![]() |
Junior Member
Thanks guys, always a big help. We ran the wire straight to the fuse block and it fired right up. Adjusted the timing by ear for now. What should the timing be set at for a 283? Idles so much smoother with the HEI.
#9 | |
Here you go on the timing question: http://67-72chevytrucks.com/vboard/s...d.php?t=248959 You'll want to open up your spark plug gaps a bit to .045. |
