Between Trucks...
Aftermarket gauge light wiring...
Got some aftermarket gauges, I'm in the middle of hooking everything up.
The instructions say to wire the lights for the gauges between the dimmer control switch and the dash lights, where should I be hooking up the positive connection? ![]()
Beat it to fit, Paint it to match... ![]() |
Re: Aftermarket gauge light wiring...
If you have the original fusebox there is a male spade conector that say something like clst feed or something or inst feed.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Or you can ground the wire to the bolt the holds the fuse box to the firewall.
1997 GMC Sierra Ext 1965 Mustang |
its all about the +6 inches
Between Trucks...
Thanks for all the replies, I love this place...
Between Trucks...
Gauge lights not working, I'm pretty sure the ground is good because the voltmeter is working, any ideas?
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 08-06-2007 at 12:26 AM. |
Post Whore
![]() Join Date: Feb 2000
Do they light up if you give them juice from a different place on the fuse box?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
i always got power from the wire that feeds the lights on the ac/heater control//never assume a good ground
Between Trucks...
I got them working, the headlight switch is intermittent and needs to be swapped out...
