4x4 frame help needed
I may be missing a cross member for my frame what does your frames have??...well i don't know if its really called a cross member.
on my frame from the rear this is what I have 1. near the rear of the truck 2nd one that is smaller i think it's for a spare tire. 3rd with a hump that looks like it's for the drive shaft if the truck sat really low right before the frame dips down. all with rivits next would be for the trans/transfer case that bolts on. should I have one were the back cabmounts are? I don't have one there. 1969 long bed Last edited by xshadow; 08-05-2007 at 07:01 PM. |
![]() Join Date: Feb 2001
Re: 4x4 frame help needed
I don't believe there is one under the cab other the the TC crossmember. There are two in the front.
On the frame,there is the front one which is sorta a "v" shape.Then there is the motor crossmember,the t-case crossmember,on the trucks w/ carrier bearing there is a crossmember,there is another with a notch in it in case the driveshaft went up that far,a little c channel one,and then the very back crossmember... 7 total crossmembers on carrier bearing equipped trucks,6 on ones w/out carrier bearing.
Thanks that helps. I have the correct amount.
I was looking at the frame in the for sale section and it looked like it had one near the back cab mounts |
