Old 08-05-2007, 07:33 PM   #1
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Trouble code 032.. EGR bad?
I've been having this code for awhile now... the truck stalls when accellerating and then the check engine light comes on. I havent replaced the EGR yet... but I did push on the diaphram and it hesitates a bit. with that said and what I have read- it appears that the EGR is okay? My gutt feeling is telling me to still replace it... whats ur thoughts??
Thanks!
Anthony
CLASSIC87' is offline   Reply With Quote
Old 08-06-2007, 10:22 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Trouble code 032.. EGR bad?
First thing to do is remove it and hook a hose to it submerge it in H2o and either blow or suck or both and see if it has any leaks.
Next with the valve removed from the H2o suck on the hose and and let go the diaphram should return to the closed postition slow and smothly without any sticking if all this is good then you need to look at the vaccum connections fittings lines if there good then look at the Ele. connector on the vaccum solinoid for any corrosion or any other defects. if it looks good then it may be the solinoid but you should test it befor you replace it.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 08-06-2007, 10:49 PM   #3
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Thanks 4 the info... I removed it and tested okay- also I replaced the gasket. Went for a drive and recheck my codes and Im getting a 43 & 44 (which I remember of getn these before as well). These conditions have been kickn my butt for awhile- im determined to get it soon!
Old 08-06-2007, 10:58 PM   #4
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
hey, sorry to hijack the thread, but im having the same problem, a constant miss, especially whne teh engine is put on a load right after idle. its a 84 motne carlo we just bought with 34k on the clock, weve replace cap, rotor, plugs, wires, and still no sucsess, and our guy siad it might be the egr valve, any other oppinions?
Sorry for the hijack,
Rspnecer
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 08-06-2007, 10:59 PM   #5
Walts_restoration
oh, and im getting no check engine light
