Old 08-05-2007, 09:47 PM   #1
herb101
Used Register
herb101's Avatar
VSS with an NP205
I am gathering the parts for a TPI conversion and need to get all the sensors. What have others done for the VSS in a 4x4 installation? The VSS units I have seen are for use in the tailstock of a 700R4, but mine has no tailstock and the speedo goes in the T-case.
Thanks,
Herb
herb101 is offline   Reply With Quote
Old 08-06-2007, 01:00 AM   #2
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: VSS with an NP205
There is a VSS adapter that splices in to your speedo cable. Here is the link to what you asked for.
http://www.howellefi.com/shop/custom...1&cat=0&page=2
Also the company that it is from is called Howell Engine Development. They have a great reputation for EFI conversions and may be able to help you out with other parts and information as well. I have never used them, but everyone else that has, really liked to deal with them.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 08-06-2007, 01:04 AM   #3
herb101
Used Register
herb101's Avatar
Awesome! Thanks.
I am familiar with Howell on Jeep EFI conversions - I've heard good things too.
Herb
Old 08-06-2007, 07:09 PM   #4
ABHaulR
ABHaulR's Avatar
they are real good. i have a harness from them for my 4.3 into a samurai. its a good comp. i have there vss sensor that that works with the cable. you remove the cable from the t/c then install there unit then install it into the t/c.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 08-07-2007, 10:31 AM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's mine on my 205.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-07-2007, 12:01 PM   #6
herb101
Used Register
herb101's Avatar
Great info - thanks guys! My harness came in yesterday, so its now a matter of rounding up sensors, bolts, T-stat housing, a MEMCAL for the computer that should be in soon, modifying the harness, fabbing intake ducting, repinning the weatherpacs for the speed density ECM, and time enough to swap it all in.
Herb
