Between Trucks...
Water out of my exhaust...
New truck, I've got water coming out my exhaust. I knew I'd have to replace the motor, but I was hoping I'd have a little more time. Am I right in thinking it's the head gaskets? Big wet spot out of both sides...
Beat it to fit, Paint it to match... ![]() |
Re: Water out of my exhaust...
uh, no. should be okay. its just condensation from the the pipe getting hot. unless you have gallons of water coming out and your radiator is emprty , you should be okay. but hey maybe im wrong.
Your engine produces something like 8 pounds of water vapor for every gallon of gas it uses. Exhaust systems rust from the inside out...
Between Trucks...
Thanks for the replies. What a relief.
H2O: a byproduct of combustion, imagine that?
Between Trucks...
67-72 Addict!
I fired my truck up last night for the first time in several months and had alot of water droplets all over the floor of the garage on both sides.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
just to be clear i was sorta bein a smart @ss about the whole empty radiator thing.
![]() Join Date: Feb 2001
Keep an eye on the water level in the radiator. If it goes down it could be the gasket or a cracked head.
Ever heard of Beech Island??
also, check the oil to see if has water in it.
I second the "keep an eye on it."
Also, take your radiator cap off & watch for bubbles. They should settle out in a few minutes.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Between Trucks...
I'll keep my eye on it. Seems weird though, water out of both sides. Not a lot, but more then looked "normal". What are the chances of both head gaskets going south, or cracking both heads at the same time? I'll check it out today sometime and see what's up with it...
#13 |
You'd be blowing blue smoke too probably if you were burning water I think, at minimum the oil would be chocolate milk, if those things are good, then, you are good
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
#14 |
Between Trucks...
I went to change the oil this morning. No water in the oil, but the person who put the oil filter on last put it on so tight, I couldn't get it off. Put a crack in the filter, had to get down to the corner gas station and pay for an oil change.
I think the water might have been condensation or something, seems alright today...
#15 |
...It's not for everyone but, if you're running anti-freeze, a sure way to tell you got a problem is to get a drop of the condensation from your tailpipe on your finger and stick it on the end of your tongue. There is no doubt you'll recognize the taste of anti-freeze.
Ironhead Mike '68 Panel 402BB '84 Shortbox 4X4 '85 Blazer '97 Silverado Ext. Cab |
#16 |
No offense ironhead but thats just nasty yo
![]() sometimes after a good run some water will form at the oil filler cap. same chocolate milk color but just a little spot.
