Old 08-06-2007, 01:15 PM   #1
whatnow123
whatnow123's Avatar
Front Roll Pan Install Help!!
Hey Everyone,
I bought a front roll pan for the 67. Looks to be a well made piece and I bought it from Mar-K. Anyway when I received the roll pan, I laid it on top of the grill (the grill was upside down as it's not currently on the truck) to test fit it and to determine the best way to install this piece. While doing that, I noticed that the curve along the length of the roll pan is off compared to the grill piece it attaches to. So, I lined up one end of it flush to the grill and it seems to be off by well over an inch on the other side. My first thought is that the grill was bent, but that isn't the case as it lines up perfectly with the fenders and there is no sign at all of it ever being damaged. The roll pan doesn't appear to be damaged in any way during shipping either.
Is the roll pan made wrong or is there a trick to installing these?
Thanks!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 08-06-2007, 02:08 PM   #2
cdowns
cdowns's Avatar
Re: Front Roll Pan Install Help!!
you need to trim a piece off the front of each framerail for starters on most of the pans i've seen
Old 08-06-2007, 04:17 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Try centering everything.There is probably some excess on each end of the roll pan so you can trim it to fit when you mold it in.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-06-2007, 05:21 PM   #4
whatnow123
whatnow123's Avatar
Here is some photos of what I'm talking about. It looks simple enough to "pull" the rollpan over but it's actually a very well built piece of metal and if I try to change the curvature of it, nothing good is going to come of it. I have Mar-k checking it as well. To be honest, I'm not sure what I'm going to do if they say nothing is wrong, as I have already cut the horns a while ago knowing I'm going with a roll pan. My grill is in really good shape (considering it's 40 years old) and has no signs at all of any type of major damage.
My thoughts are it's made wrong and it shouldn't be this far out of whack. Anyone installed one of these? Advise?
Build thread:
Old 08-07-2007, 05:15 PM   #5
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
We replied directly to this customer, but wanted to pass the information along to anyone who might be interested in our front pan.
Here is part of the email we sent:
"Do you happen to have the baffle panel (or the splash panel) that goes
between the grille and the radiator core support? This piece will
establish the exact curve of the grille when they are bolted together.
If the grille is bent, then the baffle panel will not fit match the
shape of the grille.
We make our front pan to exactly match that baffle panel. The
recommended installation is that you would slide the front pan flange
between the grille and the baffle panel. When you push it all the way
in, the curve of the pan should match the curve of the baffle panel and
grille. Then you bolt the baffle panel to the grille with the flange
in between."
We also faxed him a copy of the assembly manual that shows the grille and baffle together.
Complete instructions for the front pan are available here:
http://www.mar-k.com/GM_67-72_Front_Pan.pdf
Hope this helps!
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 08-07-2007, 05:30 PM   #6
jb4short
Damn Yankee
jb4short's Avatar
Nice...I think I want one of those- it's sharp!
jb4short is offline   Reply With Quote
Old 10-15-2007, 10:16 PM   #7
brossow
Amateur Rust Fighter
brossow's Avatar
Not to revive a dead thread, but I'm wondering how this ever turned out. Considering a front rollpan for my '72 and want to avoid problems.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 10-15-2007, 10:52 PM   #8
whatnow123
whatnow123's Avatar
Turned out fine. The grill was a little out of whack, but it looks great now. Click on my build thread, there is a photo of it mounted.
Build thread:
Old 10-15-2007, 11:37 PM   #9
brossow
brossow's Avatar
Looks great! Overlooked the pan earlier today when I was skimming through your build thread instead of doing real work. Thanks for the pointer.
Brent
