Rack & Pinion Steering?
I sectioned my front cross member and now my steering shaft is hitting my upper A-arm. Has anyone put a rack & pinion in a 72 chevy blazer??? Please help.
I am a Referee of life.
Re: Rack & Pinion Steering?
I'm pretty sure Porterbuilt does R&P with his dropmemeber.I don't know much about using it with a stock or sectioned crossmember.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Yes there is a member on here that has done this. But I believe he is in the 50's section on the site. Can't remember his name, but he was real nice even sent me a detailed cd of pictures and measurements and such on his rack and pinion. I'll see if I can't dig it up.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
clever title here
I am having the same issue if anyone know what rack i need to buy.
I was able to make my factory steering work. But I will be curious to see what fletch4x4 does on his steering.
We should work on trying to find a way to adapt this. It cannot be hard.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Epoxy Primer Friendly
I made mine.
Camaro thunder- Did you use the stock tie rod ends? What did you use for adjusters? Did you have to use a rack extinshion?
I have been looking into this also and I think a lot of the aftermarket crossmembers use ??-87 thunderbird power steering racks.
1972 Blazer body...need to get a thread started for the rest of the story |
5/8 rodends for tie rods
Billet adjusters to go from the 5/8 to rack. Manual Flaming River rack and pinion Stock crossmember with the ends/cups cutoff and bag brackets welded up. |
