Rear gear??
Right now we are running the stock ratio which seems to be a 4:10, 3 grand + @ 60 mph. My son wants a 3:73 I on the other hand work with an old engineer who worked for DANA fo 30 yrs. He says to go with a 3:42. The super charger will be on it in the next mnth so... any help, ideas or opinions will be welcomed. Also which posi unit do you guys like, I always ran the detroit locker in my Fords. My friend says stay with the lim slip??? Ok lemme have it this is a soonest thing. Thanks Mike..........
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
its all about the +6 inches
Re: Rear gear??
What's the truck going to be used for?
What size engine? What cam? What size tires? What tranny? What stall converter? Lotsa info needed to give an acurate answer. |
Re: Rear gear??
hmmm. I was running 3000rms @ 60mph with 3.73 gears with 16 inch tires and changed to the 3.08 gears which made it quit screaming somewhat. How is the truck gonna be used mostly.
R.I.P. Killer 71 10/26/07 |
The LuvShack Garage
Re: Rear gear??
Supercharged? If it's a T350 Auto you might want to go lower than 3.42
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: Rear gear??
you've got 3:73's now. my truck is doing the exact same thing. going to go to a tall tire first before i drop the bucks on different gears.
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
Re: Rear gear??
pop the cover off, there should be a stamp on the ring gear of the number of teeth....calculate the ratio. Sounds like an OD tranny may be a better way to go.
For any kind of street duty on street tires I would not go with a locker. I have an Eaton Limited slip in my pickup and have had no problems with it. Also, I have a detroit true trac (gear type limited slip) in the front of my jeep. I've had some issues of spinning only one tire at a time, a little brake pressure helps that. This isn't really an issue when offroading, but may be one on the street so I don't think I'd use the true trac again. |
Re: Rear gear??
The truck is for play time only, it will be driven daily though. Right now it has a M-21 4 spd., 20 inch Rims, 4-bolt 350 bored over slightly, 300 heads, somewhat wild cam and as soon as possible the super charger. (It is sitting in my sons room as we speak). When I was running the stock 15's it was @ aboyt 3400 rpm @ 60. It has dropped since the 20's went on. I ask only because my freind told me the 3:73's will be about the same as I'm running now. So...is it 3:08's or 3:42's, Eaton lim. slip or a Detroit locker posi.??? Thanks, Mike.....
Re: Rear gear??
I have a Power Trax No Slip unit in the Dana 60 on my C20. I don't like it. On dry pavement the truck lunges to the left when I stomp on the gas. On wet pavement, even the most gentle launch spins the RR tire until the locker engages, then both tires kinda hop for a few seconds.
I want to switch to a selectable locker (ARB Air locker, OX locker or E-Locker). |
Re: Rear gear??
I'm just starting to look at tranny, gearing, etc. and this thread has me wonderin about something. I see you guys talking about high RPM's at highway speeds with gears like 3.73. But I know one two of my current newer vehicles that's not the case.
For example, I have an `03 GMC Sierra (2wd) and a `99 Expedition (4wd). Both have 3.73 gears, and both run 265/70/17 tires. The Expy is turning around 2100rpm at 70 and the GMC is at about 2100 - 2200 or so at 70. When the Sierra had 255/70/16's on it, it was about 2300 at 70mph. So, why the big difference other than tire size? Last edited by DoobieBrother; 08-08-2007 at 01:16 PM. |
#10 | |
![]() Join Date: Nov 2001
Re: Rear gear??
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Re: Rear gear??
Isn't that what the 700R4 is supposed to be about? Hence stuff like http://www.bowtieoverdrives.com. If not, how are we getting 100mph+ trucks for the drags that still jump out of the whole but aren't turning something like 8-9K RPM?
#12 | |
![]() Join Date: Nov 2004
Re: Rear gear??
The OD reduces the final gearing about 33%. My 67 with a 350, 700R4, and 3.73 will spin about 21-2200 rpm @ 65-70 mph. If this truck really is just a play toy, I'd leave what you've got in there. I'm assuming your adding the supercharger for more fun and power? Putting in higher gears is going to kill your launch time and make the money you've spent on the supercharger kinda pointless? I'd put in a good set of 3.73 if your truck doesn't have them already (that seems a little unclear at the moment?)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#13 | |
Re: Rear gear??
#14 |
Freeeeee Mason...
Re: Rear gear??
Yeah my mild 350 does 125 all day with 15s on it and a stock 3.73 rear end. When I put the 22s on it, it dropped to around 110 though. I'm running a hopped up TH400 though. With 15s I can spin the tires all day long in the back until halfway through second. The 22"s can barely break over. My 350 only has headers, an edleb 650, and a mild cam. You should have no problem going fast with 3:73s.
