Old 08-06-2007, 07:23 PM   #1
Thealien
Thealien's Avatar
posi clutches
Where is a good place to buy clutches to rebuild mt 72 GM 12 bolt posi?
Old 08-06-2007, 08:11 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: posi clutches
Your good ole summit catalog.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 08-06-2007, 08:21 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: posi clutches
It should be an Eaton which is my favorite. GM doesn't carry clutches anymore, and none of my local auto parts stores do either. Here are a few places I've ordered from, but there are more:
You'll have to decide if you want factory-type steel clutches, or carbon fiber (I'm not clear on the pros/cons). You'll also have to decide if you want to keep your stock rate clutch springs, or go stiffer (again I'm not clear on the pros/cons).
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 08-06-2007, 08:33 PM   #4
Thealien
Thealien's Avatar
Re: posi clutches
Thanks for the quick replies
My Jimmy came stock with Posi. It is slipping pretty good so I just want to return it to stock. Truck will see little four wheeling.
Old 08-06-2007, 10:01 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: posi clutches
Would it make a noise kinda like a rear brake part dragging? I have
narrowed down a noise and thought it was my brakes, but now I'm
leaning towards the rearend since I have an axle seal leaking, it is
probably low on fluid, hense the new noise that I started to hear.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-06-2007, 10:10 PM   #6
Thealien
Thealien's Avatar
Re: posi clutches
I have a noise also, more like a U Joint but I know it is not, they are all new.
