08-06-2007, 08:03 PM | #1 |
power steering question - (quick one)
as soon as baby girl goes to bed, thinking about trying to put on some power steering lines (new setup - original parts) - on a 72, On the steering box, which is the supply and which is the return (looking at it from the dr. side wheel area). Thanks all.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 08-06-2007 at 08:04 PM. |
08-06-2007, 08:19 PM | #2 |
Re: power steering question - (quick one)
The supply, (pressure line) is on the outside and the return line is on the inside. You should not be able to install them incorectly as the pressure line has a larger fitting.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-06-2007, 08:22 PM | #3 |
huh?
I had the same question Thanks Jim!
Jim, I looked for a BB Impala shroud at the show I went to, no luck
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay Last edited by 68 Stepside; 08-06-2007 at 08:22 PM. |
08-06-2007, 08:30 PM | #4 |
Thanks for looking for the shroud! I appreciate the effort.
Jim
08-06-2007, 09:10 PM | #5 |
and thanks from me - wish me luck- headed out into the 90 degree dark, with dirt floors..MAN I mish my shop!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
