HELP!! Temp Gauge wont work.
Okay I am about at my wits end. I cannot get my temp gauge to work. I have replaced sending unit, wires to printed circuit, printed circuit and new gauge. It still pegs out on H befor I can even start it. Can anyone help??
72 Super Cheyenne lwb 4X4 Ocra / White ![]() 88 Chevy 1 ton Dumptruck ![]() 88 Chevy 1ton Flat bed 4X4 white ![]() |
#2 | |||
Union Electrician
Re: HELP!! Temp Gauge wont work.
If you are certain there is not a short in the wire from the sending unit to the gauge, then you need to change the resistor, or porcelian piecee on the rear of the gauge, you can get them form the vendore for around $10..Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
The new guage from LMC don't use the resistor. I install one on Sunday and I am having the same problem, I am changing out the printed circuit board next. You might check if you have 12 Volts on the guage.
My new gauge is from LMC but I used the resistor I guess I should have read the instructions DUH! Thanks for the Help!
