SWB 4X4 CLUB
Crank pulley question?
Please go easy on me. How do I remove the crank pulley on a 292 (if that matters). I did not see any bolts in the pulley itself other than the balancer bolt. There were three holes that look like they should have bolts in them. Thanks.
Jason |
Re: Crank pulley question?
Yes there should be three bolts securing the pulley in addition to the crank bolt. If the three bolts are already gone, just remove the crank bolt. If you need to pull the balancer, install a three-position puller, tighten the puller bolt and it should come right off. Can send pics if needed....
Ironhead Mike '68 Panel 402BB '84 Shortbox 4X4 '85 Blazer '97 Silverado Ext. Cab Last edited by Ironhead; 08-06-2007 at 10:10 PM. Reason: add more... |
SWB 4X4 CLUB
Here is a crappy pic of what it looks like at present.
Is a puller necessary. I tried everything I had at the time and it would not budge. Jason |
I think you just answered your own question. Yes a puller is necessary, but I am sure people have done it without one, but I prefer to do it the easy way.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
