Old 08-06-2007, 10:01 PM   #1
Shane
Shane's Avatar
rear lugs when running rear discs ....
what are you guys running for rear lug BOLTS after you install rear disc brakes?
i am finding that the additional approx 1/4" thickness of the rotor takes up valuable thread and that even with a steel rally wheel, the lug nuts will only spin on about 2-3 threads ... not even allowing the end of the lug bolt to sit flush with the face of the lug nut.
i have searched and searched for longer lugs (locally and on the 'Net) and can find STOCK thread and shoulder dia lug bolts... I can find LONGER lugs, but not with the same size shoulder that passes thru the axle flange. I would like to have something at least 3/4" longer, but can't find them in stock size threads or shoulders. Advice?
I have even had the thought of removing the axles, drilling and tapping the axle flange and then using Grade 5 bolts with Loc Tite as lugs ...
any advice on where to find "stock" style lugs but longer?
pros and cons on using Grade 5 bolts?
What are all the guys running rear discs using?
Shane is offline   Reply With Quote
Old 08-06-2007, 10:49 PM   #2
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Re: rear lugs when running rear discs ....
You're looking for studs, not lug nuts, right? Have you tried ARP? That's the first place I would try.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 08-06-2007, 11:42 PM   #3
Shane
Shane's Avatar
yes sir, studs ... lol. been a long long day
Old 08-07-2007, 12:28 AM   #4
SCOTI
SCOTI's Avatar
I don't have rear discs (yet), but I did have to swap the studs on my original axles years ago & was having the same problem. I wound up using long studs from Moroso & then cut them down to the length I needed.
Not as visually appealing, but it got the job done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-07-2007, 08:54 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
I don't think I'd bolt my wheels on with them, especially when grade8 is readily available in the same sizes for not much more money. Even then, I think I would prfer a stud. Like these guys said- Moroso or ARP.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-07-2007, 10:58 AM   #6
rodnok1
rodnok1's Avatar
Do not use grade 5 bolts,wheel studs are hardened. I got my studs from Moser when I bought new axles. you should be able to get studs from Napa.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-07-2007, 09:46 PM   #7
Shane
Shane's Avatar
Where did you find the Moroso studs with the correct shoulder diameter? Snow ball's chance in hell here, but you wouldn't still have something that might have a part number on it, would ya?
I have a set of the Moroso studs in the blister pack, but the shoulder diameter is gonna require that I drill the axle flange ... and that's what I am trying to get away from. If I go thru all that trouble I am just gonna drill and tap for a bolt.
Old 08-07-2007, 09:46 PM   #8
Shane
Shane's Avatar
Napa can't get stock studs in longer length, at least my local Napa can't ... been there, done that.
Old 08-07-2007, 10:20 PM   #9
SCOTI
SCOTI's Avatar
This was a while back so no go on the P/N's. They did come in a blister pack but I don't recall having to drill the holes out for installation.
Wish I could have been some help.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-07-2007, 10:30 PM   #10
Rickey
Rickey's Avatar
Go to the Moroso web site and look under brake wheel equipment and choose the stud that will work might have to cut off to size.
Rickey is offline   Reply With Quote
