Old 08-06-2007, 10:28 PM   #1
notahybrid
Fuel Pump Question
Hey, I have a 68 c10 w/ a 250. I am having a problem that I think may be due to hte fuel pump. When you take the fuel line off the carb, should there be a steady stream of fuel comming out with the engine running? Mine currently is pulsating and I think is starving the carb. Thanks
notahybrid is offline   Reply With Quote
Old 08-06-2007, 11:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Pump Question
that's how it is supposed to work.
Old 08-06-2007, 11:09 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
you sure? cuase ive always seen a stream rather then pulses
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-06-2007, 11:09 PM   #4
Ironhead
Ironhead's Avatar
If you run a line into a container such as an quart oil bottle, crank the engine over without starting. At a minimum a stock pump should pump about a pint of fuel in about 30 seconds or less. If you get less than a pint in 30 seconds, look for a restriction in the line such as dent or kinked line, pinched hose, or clogged fuel filter. Reconnect the fuel lines and perform a pressure test by installing a gauge near the carb and start the engine... should show 4 1/2 - 6 pounds of pressure for a 250. Stop the engine and note if the pressure... should drop off slowly... I pressure drops quickly, the outlet side of the pump may be leaking. If these checks are good and you feel the engine acts like it is starving for fuel, double check the ignition system. Good luck...
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 08-06-2007, 11:13 PM   #5
GREASEMONKEY72
dont forget to check the lines for cracks and splits
-steven
Alte Seele S.S.
Old 08-06-2007, 11:27 PM   #6
Longhorn Man
a mechanical pump will always work like that. An electric one will do a steady stream.
Old 08-06-2007, 11:31 PM   #7
GREASEMONKEY72
i know the electrics will but if i remember right the mechanical will put out atlest almost a steady stream not like major pulses is what i ment
-steven
Alte Seele S.S.
Old 08-07-2007, 06:57 AM   #8
notahybrid
I appreciate everyones help!
Old 08-07-2007, 08:55 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Pulses at low idle and may look like a stream at faster idling. That's how it works. A lever pushes against a diaphragm to create suction and pressure action...
Now, if you have a weak diaphragm, plugged sock in the fuel tank or restricted fuel lines (that's what my problem was) it will cause a weak stream.
Fuel pumps are cheap and easy to replace if you suspect it.
68gmsee is offline   Reply With Quote
