![]() Join Date: Feb 2001
When it comes to TRUCKS…what has been the dumbest thing you have ever done??
OK...I'll go first. 30 years ago my Dad gave me his truck. It was a 54 Chevy 1/2 ton. Then about 6 months later I sold it for $125.00 .
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
"1972 C5"
Re: When it comes to TRUCKS…what has been the dumbest thing you have ever done??
Sold my 85 silverado that was my DD to a guy down the street. Wouldn't have been as bad if he lived farther away, but I have to see and regret every morning on my way to work. Bummer man.
Home alone, got ready to look at rear brakes - put jack under pumpkin, collected blocks to block the wheels. I was under the carport hooked along the side the house (smooth concrete sloped downhill to my shop). Was just getting staged, only wearing a pair of shorts... went in house, came out, put jack under rear end and started raising jack - both wheels in the air, realized I left out the blocks! The whole rig started rolling backwards towards shop - I was able to jump in and hit the brakes. Ebrake couldn't do anything, it was in gear but rear was in the air so that didn't do anything for me either. I sat there for 20 minutes trying to figure out what to do - there was no way to get out, get to the blocks and get back, lower the jack or anything. My cell phone was 10 feet away. I sat there swithing legs on the brake until they started to ache.... I realized the jack was rolling on the little 1 1/2 inch wheels and staying balanced. I also realised that 20 feet farther back, the driveway had a seam across it. I slowly creaped it the 20 feet until the rear set of jack wheels came to rest in the seam.... I slowly slipped out, ran to the blocks and got 'em behind the front wheels. Then I threw myself around for being careless. The truck was my brand new 2500 Ram TD and there was no way the truck or carport would have faired too well.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
R.I.P. Killer 71 10/26/07 |
Traded in my Dad's '68 Camino in as a down payment on a 91 Nissan Sentra....You know....I still hate my ex wife for that one....
cant really think of anything at the moment but im looking forward to the stories thats for sure
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Nothings as cool as my 72
Too many to think of. I had one situation similar to luvlegs but my truck fell off the jack. Since im working on my truck in my backyard i dont have level ground to work on. Well one day I had my wheels off to get the new tires for put on the rims I had the front supported by two jack stands and the rear supported by one jack in the middle of the rear axle. Well while I was in the cab do some wiring work the truck just fell off its jack stands. I guess since in working on top of soft dirt and getting in and out of the cab while I was doing my wiring made the jack fall over. Im just glad I wasnt under the truck when it happened. I guess another dumb thing Ive done with my truck is let my cousin get involved because it was his idea to do a whole frame-off resto when I didnt want to at the time. Came home one day from school too find my truck half torn a part. Well two and half years later and over ten grand spent and shes almost done except for the less then perfect body work. Didnt think it would take this long and cost this much.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
Well, I shouldn't even admit this, but now looking back, I find my stupidity kind of funny. And it was REALLY stupid.
A few years ago I had decided to run some Seafoam through my `03 Sierra. No biggie. I had done it before on my Expedition without issue. So, I pulled the brake booster line and w/ truck running started running some SeaFoam down it. My technique was, of course, the origin of my problems. I did a little at a time letting it recover. Did about half the can, then killed it and dumped in the rest. That was the problem. I didn't shut it off with the key. I let the seafoam kill it and then kept pooring and finished the can. Well, we all know liquid doesn't compress like air. So, guess what...Hyrdro lock. Problem was, I didn't know what it was at the time. I got in to crank the truck up after letting it sit for a while, and of course, it felt like the engine was locked up. Well, it was. With liquid. But wait, it gets better. After figuring that I was hyrdolocked, I pulled all the plugs. It was obvious which one was the issue because when I pulled the plug, the Seafoam poured out. So, here's where in my continued state, of "Oh, my gawd I've screwed up my truck" and not thinking well enough, I "thought" I disabled the ignition. Pulled the plug right up against the side of the throttle body. Must not have been it, because when I cranked the truck...now don't laugh, I sparked and ignited the still wet Seafoam. Fortunately, I had a fire extinguisher about 6 feet away. One squeeze (dry extinguisher) and it was out. No damage. Was just the Seafoam burning. Stop laughing. Anyway, I put all the plugs back. Plugged everything in, then hosed down the engine to remove any remaining Seafoam and all extinguisher soot. When I was sure everything was ok, I fired it up. It ran fine. Rough at first from the Seafoam, but the rest blew out after a while as expected. The look of horror on my face and how quickly I ran for the fire extinguisher was probably much more entertaining than the little flame up. Nothing on the truck was damaged. Just my ego was seriously fractured. Fire extinguisher made more mess than anything. What also sucked was my engine compartment was spotless before. I try not to be that stupid anymore when working on my vehicles. LMAO |
let my dad trade my first truck -> '66 350 4-spd 3/4 ton for some CRAPPY carpentry work in the kitchen
Man we could sell these stories!
Keep Your Nose Clean
I regret selling my 1985 Chevy Silverado. It had a candy midnight blue paint, Zapco system, lowered 5/7, and rolling on 17" Boyds. I sold it so I could get my wife a wedding ring back in 98. An architect bought it for his 17 year old son. I seen the truck at a Home Depot about a year later all banged up. I almost cried.
![]() Last edited by MisterE72; 08-07-2007 at 01:13 AM. |
#13 |
To be old and wise you must first be young and stupid... I'm young so what is this Seafoam? Octane booster; Engine cleaning stuff?
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
#14 |
72 chevy
![]() Join Date: Jan 2007
Had a guy buying a tc grade trap Remington shotgun from me and didn't have anuff money but wanted it real bad. Well he traded a 72 ford 1/2 ton truck for the rest of the money if it would of been a chevy i would of been thrilled to death. well it took all of 3 day to destroy that ford. Wait you said dumbest i was thinking funnest. LOL!!
#15 |
Freeeeee Mason...
Filled up my 05 chevy duramax with gas... :-/
#16 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I gave my oldest son, (when he was 15, now 25) my '58 Apache stepside right before I moved to England. I found out a year later that he traded it for a POS four wheeler that stayed broke. The truck had a '78 Corvette 350 w/saginaw 4-speed and 3:73 posi rear. All he had to do was finish running the brake lines. I haven't given him anything since.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#17 |
Damn Yankee
Spent a bunch of money on a DODGE!
#18 |
Rottenwood Garage Member
Buying a Vortec and then buying another one!!!
#19 |
68 just like me
parked at the top of my drive without setting the brake about 3 weeks ago totalled front clip and warped frame
68 just like me ![]() |
#20 |
![]() Join Date: Jul 2006
I was "attempting" to wire an electric fuel pump into my ignition. Somehow or another I wired it to were the truck started itself in gear and drove up the driveway with me chasing it and ran into the corner of the garage. Doh!
I decided to stay with a mechanical pump shortly after that. ![]() |
#21 | |
#22 |
Junior Member
![]() Join Date: Jun 2007
Let's see.....a few years ago I decided to replace the intake, carb, and cam on my 327 with one of those packages from Edelbrock. At the same time, I converted my distributor from points to electronic with one of those breakerless kits from Pertronix. Installation was uneventful, buttoned everything up, crossed my fingers, and started her up. Well, I was stupified that the thing even started, so I was like "Hot dog! Look at me, Master Mechanic!". It ran a little rough but I thought, "Hey, I'll break in the cam and dial the timing in later." So I revd her up to the break in RPM, put a pair of Vice Grips on the linkage to hold it there for the required 20 minutes, and ran into the house to grab a drink and brag to the wife about my mechanical prowess. I returned to the garage about 10 minutes later and the truck is still running (although the exhaust note was strangely different). Then I noticed the smoke coming out from under the truck and the plastic trash can next to the tailpipe melted, blackened, and smoking. When I look under the truck the exhaust pipe and manifolds are glowing bright cherry red.
"A man's got to know his limitations." - Dirty Harry _______________________________________________ 1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker |
#23 |
'69 Step
I was at the drive in movie with a girlfriend in high school driving her dad's truck. When I leaned over to kiss her, I inadverdently pushed the clutch in and the truck rolled into the speaker pole. It dented the door and ripped the side mirror off; expensive kiss.
#24 |
![]() Join Date: Aug 2005
Back in Highschool I cut speaker holes in the doors of my Dad's '64 (which was later passed on to me). That's not so bad, but I cut both holes on the same side of the doors as you face them from the inside/open. So I had a speaker at the front of one door and the rear of the other
#25 |
'69 Step
I had a cousin cut a speaker hole in a car door one time and he cut both the inner and outer door skin.
