![]() Join Date: Nov 2006
best way to access windshield washer pump
i,ve got to swap out my windshield washer pump and its on the back of the wiper motor right ? will pulling the instrument panel let me access it good ? my truck has a/c also.
bob
I BELIEVE IN JOHN 3:16 |
Re: best way to access windshield washer pump
Yes. Thats how i did mine a few years back. Especially since you have a/c.
thanks
"Trucks with Class"
![]() Join Date: Jul 2000
Forget it! They are junk & hard to get at.
Install a small electric pump next to the washer bottle...easy to install and easy to replace. |
I Want My Truck To Be As Original As Possible.
Thanks Pickmup. Thats What I,ve Done On My 2 , 1972 C30 Work Trucks Though. Bob
Do you have to remove the instrument panel to get the motor out as well? I have to get a new wiper motor.
I havent had any problems with the replacements. And the oe one in my orange and white worked till I took it out of service in 2000.
As for replacing the wiper motor. Yes remove the cluster. And you will have to remove the cowl to to undo the motor from the linkage. Last edited by Aarons72s; 08-07-2007 at 09:10 PM. |
the service manual says remove the ignition switch and it can be accessed but i agree it is much easier to remove the cluster
common sense isn't so common anymore |
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
It seems to me that removing the ignition switch would not help very much.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club Last edited by Jwill41; 08-08-2007 at 08:57 AM. |
