Front suspension Ideas Will it work?
Question 1...... I was wondering if I can use 73-87 a-arms, shaft and spindle on my 68 with out changing my engine cross member will it it bolt up to the 73-87 spindles.
Question 2....... If I can't do the above idea I was thinking of getting tubular a-arms but the sales rep told me I could get the 73-87 style ball joints that will fit the 73-87 spindles will these be a direct bolt on if I get the 68 style tubular a-arms with 73-87 style ball joints?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
Re: Front suspension Ideas Will it work?
ttt
Too Many Clubs Club
Yes, they'll fit. I put '76 A-arms under my '68.
How I installed my air bags... |
Cool thanks I think I'm going to order a set of tubular arms and spindles 87 pick-up style I think they are a bit beefier tan the pre 72.
On a second thougt it just hit me by seeing some pics of suspensions I think I already have the 73-87 front suspension I/'l take some pics so someone can tell me but anyway I was thinking on getting this...
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 Last edited by oscareltemblo; 08-08-2007 at 12:24 AM. |
Here is a pic if someone can see it and tell me if it is the 73-87 style or original 68. [IMG]
Official Site Guitar Shredder
looks stock to me
Looks like it has a bushing 'shell' & is of the press-fit variety. If that's correct, it makes it a post 73 upper a-arm.
![]() Join Date: Aug 2005
Either way, you can use 73-87 spindles on it.
On the fast track to nowhere..
Only issue I know of is that the tie rod hole on the spindle is larger on the 73-up spindle. I imagine you could just change outer tie rods to compensate.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
thanks.
