Old 09-24-2002, 09:57 PM   #1
conman
Longhorn rearends
I know the Longhorns may have came with different rearend configurations, but can anyone tell me say the most popular top 3 different ones. I own a 72 longhorn with leaf springs. I know it isn't posi but that is all.
Fayette Alabama
conman is offline   Reply With Quote
Old 09-24-2002, 10:15 PM   #2
Mike C
Mike C's Avatar
Do you mean gear ratio? Or do you mean Corporate vs. 60? Most 3/4 ton trucks will have 4.10 or 4.57 gears depending on options. My GMC Longhorn pats truck has 3.73 in a 60, but the glove box sticker says max trac axle, but it is open, so could be gears were swapped or could be just the diff was swappe. Dunno. Big block trucks usually got a 60 with 3.54 gears.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-24-2002, 11:33 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
The longhorn only came with leaf springs first off. The big block came with the dana 60 and 3.54 gears as standard. All other engines would have had the HO72 corporate axle as standard. My 69 longhorn has the HO72 with 4.10 gears.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
