86 vs 1987 Fuel Injection - Cab differences?
Have an 86 gas (carb), and 87 diesel
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: 86 vs 1987 Fuel Injection - Cab differences?
there is no cab difference on EFI vs non-EFI, the ECU for the carb mounts in the same place as the TBI ECU...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Great. How about the diesel cab? Did they plug the ECM wriring hole? Or use it for the glow plug controller and such? Manuals are coming but trying to decide if I should build 1 nice or 3 drivers. Thanks again.
The Crazy Machanic
how about 1 nice and a driver
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Next!
Big difference between the trucks in the fuel lines. TBI lines are different than carbed lines.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
You also want the gas tanks and all associated wiring. Those TBI tanks have the in tank electric pump with the correct fuel pressure for TBI.
I thought he was only asking about cab differences?
Yes, only cab differences. I'd forgot about ECM and carb (went from 82 gas to 87 diesel with 2 1990's and '99 in between). I'm pretty uup on the fuel systems and such, but the diesel is new to me. I can't imagine there are significant difference sin the cabs but thought I'd try to find out before getting started - usually I find out when everything is apart and undriveable.
On the Diesel, it should be any different either. I can't remember where the glow harness comes out, but I don't thing the hole is there. Don't quote me on that...
