Old 08-07-2007, 10:26 AM   #1
bossrod
WTB: Door parts for 72' C-10
If there is anyone out there that is parting out unusable doors from a 72' Chevy C-10, I could use the screws and washers used to pull the inner and outer door panels together. I'm referring to the ones directly under the vent window locks that extend from the interior of the cab out to the exterior door panel. They are used to pull the panels together where the vent window post goes down into the door cavity. The washers fit the contour of the door at the screw hole. Hit me with a PM if you need more info. Thanks...bossrod
bossrod is offline   Reply With Quote
