I was just wondering if anyone has tried the edelbrock e-tec top end kit for a chevy 350 and if so is it a good buy? i will be working with a performance bottom end and my goal is 450 or 500 hp! one way or another.
Re: Question on top end kit
Anybody?
im kinda wondering the same thing. i will be building a engine for my truck sooner or later.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I haven't used the E-tec heads or the kit, but I've been considering it. IMO it is a good buy considering what it is capable of producing. I think to acheive your desired hp goal, you'll need to upgrade to a bigger roller cam and probably bump the compression up a little. It might be a little easier to get those numbers if you went with a 383 or 406. If you haven't already, post this question in the engine forum.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-10-2007 at 12:46 AM. |
