?POR-15 before spray in bedliner
I'm in process of fixing all my floor pans right now then will get the whole inside Rhino or LineX. Should I POR all the bare metal parts first or does it matter?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
The LuvShack Garage
Re: ?POR-15 before spray in bedliner
I would, but this is a personal preference, not sure you need to
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I would like to hear the opinions on this also
i know most all bedliners suggest painting before bedliner spraying// the thing about por15 is with regular paint theres a problen with the paint adhereing to por15 unless you use the por15primer// what i do with por15 i paint the por15on then when its still tacky about 3/4cured i spray epoxy primer on to assure a good bond for the primer to the por15
urban fourwheelin
same....
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
I did POR-15; Por Tie Primer; Overspray from body primer and body paint; scuffed it up really good with 80 grit then sprayed in the bed liner and I am happy with how it came out. Time will tell how it lasts though; that was only two months ago.
John |
