Old 08-07-2007, 07:02 PM   #1
wugunguy
70 C/10-Work in progress
wugunguy's Avatar
Is this a dealer installed option?
I just took this off a 72 Cheyenne. I think it's a brake sensor for trailer brakes? It was mounted on the steering column and had a hard line going to the P-valve on the master cylinder.
Was this a dealer option or is it junk
thanks in advance
In the garage
1999 Dodge Dakota Sport-Daily Driver
1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt
1970 Chevy C/10-Current project
wugunguy is offline   Reply With Quote
Old 08-07-2007, 07:11 PM   #2
cory321
Problem Child
cory321's Avatar
Re: Is this a dealer installed option?
I have something similar not sure if they are dealer installed or not.
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 08-07-2007, 09:04 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've never seen anything to indicate the dealers would install one... but it is a possibility.
Any kind of GM markings or anything?
Old 08-07-2007, 09:17 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have one on my truck, that was for the electric trailer brakes on the travel trailer the P.O. used to pull. There should be an electrical connection from the battery to the box and wiring from the box should go to a 7-pin connector on the back bumper. The trailer would have a plug that would hook to the truck.
But the question is whether or not it was dealer-installed. Based on the looks of yours, compared to mine (which is newer), it is at least a vintage unit.
Member Nr. 2770
Old 08-07-2007, 09:18 PM   #5
Longhorn Man
that much is certian... I think they stopped tapping into the brake system in the 80's for traler brakes.
Old 08-07-2007, 09:40 PM   #6
Dealers didn`t install those on trucks.Maybe one would,but it wouldn`t be common.
Old 08-07-2007, 09:47 PM   #7
sdkid
TEKONSHA is a current brand name for trailer brake controllers. Dealer installed, very possible. GM marketed option, I personally doubt it. My opinion only. I'm pretty sure thay haven't tapped into brake fluid for trailer brakes for many years.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 08-07-2007, 09:56 PM   #8
jott_06
Camaro Club
jott_06's Avatar
wow i never thought i'd see another one of those. I dont know if that is a dealer thing or not but my 68 GMC i bought back in feb. has the same exact trailer brake in it. I mean its identical...I live in ohio but my truck is originally a california truck.
jott_06 is offline   Reply With Quote
Old 08-07-2007, 10:09 PM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
maybe it is a dealer option deal but then it could just be that was the only or atlest the most popular model back then if theres so many that are the same, i wouldnt mind having one
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-07-2007, 10:15 PM   #10
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Yours is a "deluxe" or later style of the hydraulic controllers. It has a knob for adjusting the level of variable voltage output, which increases with more pedal pressure. Earlier designs used a panel that mounted underhood with resistance coil springs and a "slider" you could adjust the voltage output with. In ways, yours works better than the new electronic ones, because the electronic ones use an internal pendulum switch that senses the truck trying to stop. So if your truck is sliding on loose gravel or something, it doesn't know you are braking hard. The old hydraulic doesn't know any difference, as it runs off line pressure. That's why you can't use a hydraulic one with antilock brakes, thus the electronic one came into play. You can buy a pressure switch controlled electronic one for today's trucks that works GREAT, but they are pricey.
Whew! Ok class, trailer brake 101 is dismissed
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 08-08-2007, 12:25 AM   #11
70C10Toejam
Hellasick
70C10Toejam's Avatar
looks like something that would have gone with my '85 MC, never saw it before the body was pulled.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 08-08-2007, 06:25 AM   #12
My GMC has a Kelsey-Hayes wetline controller.That`s the brand I`m most accustomed to.I had spongey brakes so I did the calipers/master cyl/booster.It still would loose pedal after bleeding.That`s when I realized it was in the controller`s fitting at the prop-valve.Unhooked it.Guess that`s why they`re gone,now.That and just good ol`new technology.
Old 08-08-2007, 12:42 PM   #13
wugunguy
wugunguy's Avatar
wow, thanks for the info everyone, there weren't any wires connected anywhere-just the short ones coming out the back of the control-there isn't anyother wiring going to the rear for trailer brakes either, hmmm
thanks again everyone
In the garage
Old 08-08-2007, 02:00 PM   #14
cdowns
cdowns's Avatar
probally dealer installed by the trailer dealer
Old 08-08-2007, 04:58 PM   #15
mbgmike
Where I grew up dealers installed alot of things. My dad just called up the dealer , he brought it in and they put them on like anything else. You just walked in the shop and they gave you a price. As far as a dealer installed aftermarket part supplied by them probably not. But who knows some dealers may have offered them as an add on.
mbgmike is offline   Reply With Quote
Old 08-10-2007, 01:22 AM   #16
wugunguy
wugunguy's Avatar
awesome info guys
greasemonkey-are you interested in this? I would part with it.
In the garage
Old 08-11-2007, 12:12 AM   #17
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I doubt that was a dealer item. I saw one at the junkyard in a '84 GMC crewcab. It had the T fitting on the MC line for the rear brakes and ran to the back of the brake controller. It had a power wire and two 10GA wires for the brakes running to a 6 pole connector on the inner driver side of the bed(for goosneck trailers).
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-15-2007, 01:49 AM   #18
wugunguy
wugunguy's Avatar
R. D. Mercer-sounds like the same thing
In the garage
