Old 08-07-2007, 09:25 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Angry my radiator...
it has a about 2 or 4 pin holes and what should I do replace it or use something called barrs leak???
any help is appreciated
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 08-07-2007, 09:28 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: my radiator...
I would have a radiator shop repair it. Usually it's not that much, at least around here. I think the last time I took mine in it cost me less than $40.00. They cleaned/tanked repaired and painted it.
I gave up on bars leak and such.
68gmsee is offline   Reply With Quote
Old 08-07-2007, 09:35 PM   #3
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: my radiator...
+1 the rad shops around here are about 20 bucks an hour. had one done last year. did a great job.....id try that before bars leak
bad6772 is offline   Reply With Quote
Old 08-07-2007, 09:37 PM   #4
st1x10
st1x10's Avatar
Re: my radiator...
NO Do NOT use stop leak, it is junk and only causes more problems. Do it right and take it to the rad shop like the guys above said.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 08-07-2007, 09:42 PM   #5
70' GMC
70' GMC's Avatar
Re: my radiator...
should I buy a brand new one?
Old 08-07-2007, 09:49 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: my radiator...
They're not cheap... I've had mine repaired on the 69 chevy twice and doing well. On my 68 GMC I had them put a double row one in because of cooling problems and potential A/C in the future.
It's your call. If you feel it's rotting out and could be a continuous problem, then buy a new one or have them replace internal radiator and reuse your outside parts.
Old 08-07-2007, 09:52 PM   #7
Aarons72s
Re: my radiator...
Base price for most new radiators for our trucks at the parts stores is a little over $200. And that was 4 years ago.
Aarons72s is offline   Reply With Quote
Old 08-08-2007, 12:26 AM   #8
HeavyD
HeavyD's Avatar
Re: my radiator...
But, it will be good for many years. I think a new one is a good investment.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-08-2007, 12:43 AM   #9
Texasbigblock
Texasbigblock's Avatar
Re: my radiator...
Prices of radiators have drastically gone up recently, i priced one last year at $150, and this year the same place quoted me the same radiator at $275. So i brought my old one in and had it fixed for $20. Its been holding up good so far. Plus radiators are a quick to change so when i get the money later on a throw a new one in there
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 08-08-2007, 12:48 AM   #10
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: my radiator...
My experience with rad shops was they at least inspected it and told me it appeared solid first. It's no guarantee against future weak spots, but if the shop is good they should be able to tell if it appears to be worth fixing. If it looks good to you, $40 to fix vs. $200 to replace, I say fix it.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
