Official Site Guitar Shredder
tilt column?
i was wondering which tilt column does everybody run in a non factory tilt truck? i have heard of the chevy vans but .what years? im guessing there not just a bolt in item..any help would be awsome.... a freind of mine gave me a 92 G.T.A column was just wondering if it may work. or what kind of fab work or things do i need to look for............thanks in advance tony
its all about the +6 inches
Re: tilt column?
I'd sell the T/A one on e-bay, and get one out of a 72 - 81 van.
Check out the FAQ, there's a lot about installing one. It's not quite a direct fit.. .but pretty close. |
Re: tilt column?
I found that a lot of vans with round headlights have columns that work. Problem with a newer tilt is all the junk (wipers, ignition, cruise, high beams etc...) that are built into the column. The van tilts have a splined shaft that stops just outside the column while your stock one has a long shaft that extends to the rag joint. You just have to make or buy a piece to connect the van tilt to you rag joint.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: tilt column?
The truck columns have a intermediate shaft that comes off on both the column,and rag joint ends Mike.That piece on the van column that connects the column to the rag joint (no intermediate shaft on the vans) comes off and then its just splines like the regular truck column and slides into the regular truck intermediate shaft,or atleast it did on mine.The van column is longer so you have to collapse the shaft in some so it works though.I'm using a late 70s van tilt.Check the FAQ,there is some threads on converting a van tilt to work in a truck
#5 | |
Re: tilt column?
main point is, people use van tilts, yes it's possible and yes it's cheaper than a real truck tilt.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-08-2007 at 08:33 AM. |
Re: tilt column?
thanks guys. is the T/A column worth selling?
Re: tilt column?
I would assume a T/A guy, or a Camaro guy would love to have it... I know I hate getting in and out of 3rd gens w/out tilt.
Re: tilt column?
...Or a street rodder.
