heating springs?
im thinking about heating the rear coils on my truck,i know you need to be on level ground to do this.but is there anything else i need to know?
im thinking, set two jack stands a couple inches under the frame rails,get under the truck with a torch, and heat in the middle of the spring until it bottoms out on the jack stand? opinions on this are appreciated
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
Re: heating springs?
well you can do it that way and itll work and its certainly the easiest way to lower a truck but not exactly the safest or best ride quality is what ive heard
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Just to let you know, you are about ready to be adamantly told NOT TO DO THIS! I don't know much about it, I just know no one on here thinks that is a good idea. Safety and ride concerns. Just giving you a heads up.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
i can deal with some bumps...but i dont want a spring to break going into a corner you know what i mean?
other than ride, what is the safety concern
I've always heard that heating springs is a bad idea. If your only wanting to go a couple inches or so why not use blocks and longer u-bolts? I fabricated my blocks out of scrap 2 1/2 " square tubing. I still need to get the u-bolts made, I would guess they will run around 25 bucks.
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
heating the steel like that can make it brittle and also just weaker than before, my vote would be with some square tubing or blocks for just an inch or 2, even 3
well, it would just be tempoary until i got some drop springs. all i know is something needs to be done..my truck has that von dutch look.and theres not even a motor in it at the moment
dont take this the wrong way or anything but if it doesnt even have a motor in it and youre getting drop springs anyway then why bother messing with heating the stock ones?
if youre just playing around with it and not driveing it then heat away and play with different drops
i have a motor, i just have to get my accssories bolted up, and a few other odds and ends
ah i see, well really its up to you if you want to do it but everything ive heard is always to not do it because its unsafe and i do know that heating the steel will make it brittle and weaker
![]() Join Date: Oct 2006
DONT DO IT! My wife's dad claims to be a HOTRODDER and that is how he does it. When you heat a spring, it loses it tension and becomes unsafe. You will bounce all over the place. Do yourself(and everbody else on the road) a favor and sve for the right springs.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
i say fill your box with sand. it's much easier to reverse by shoveling it back out
common sense isn't so common anymore |
#13 |
Hellasick
![]() Join Date: Jul 2006
or use a cold-saw and cut one coil off.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#14 |
its all about the +6 inches
you can't really cut the rear springs, they are pig tailed.
I hate to say this... but wht do you guys think they've done for the last 50 or so years? It ain't the best way, but you ain't gonna go a kill yourself, or cause an accident that'll wipe a town off the map. ![]() You'll wanna wither put a real heavy load in the bed to help with pushing down, or you'll want to pull the body down to the jack stands as you heat it. A rachet strap around the axle to the frame (2 of them actually) would work... not the little girly straps, but the big thick ones. Last edited by Longhorn Man; 08-09-2007 at 10:03 PM. |
#15 |
Texas Big Wig
Wow, by the sound of it I should be dead & my truck shouldn't resemble a truck anymore
![]() I heated my coils & I drive my sh!t every day, drove it to Norwood and back ![]() And as for ride quality, maybe if you drop it 10" inches or something stupid your ride would go to crap, but I could barely tell a difference when I did mine So it's unsafe, well just like Andy said "what do you guys think they've done for the last 50 or so years?" Yeah, maybe if you heat em up white hot & douse em with water I'm pretty sure you could get one to snap |
#16 |
I've had my rear coils heated for the last 10 years with no problems - I used drop springs and shocks up front and heated the rear. I intended to get drop springs for the rear but the ride has been fine.
#17 |
More Cowbell....
Just don't put all the heat in one spot. Spread the drop out over a few inches of the spring.
But....it isn't a question of "IF" the spring will fail....but rather "WHEN" the spring will fail. You may not have an accident when it snaps, but it will flat out scare the dog-$#!T out of you.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#18 |
Remember What The Sherrif Told Mater In Cars...(tonotoo)
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
#19 |
Dont do it coils are cheap, heating the springs changes the formula of the metal since it is heat treated spring steel, not saying it wont work or that it is dangerouly unsafe but its not a good thing. If you do it stay at the top to 1/3 of the way down and it wont affect your ride quality as much since it will use more of the stock spring rate until the spring compresses enough to use the top which will then be stiffer, basically your making a backyard progressive spring.
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
#20 |
You know you are a redneck if....
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#21 |
chrome makes it go FASTER!
I saw the same edition of musclecars this weekend.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#22 |
Texas Big Wig
So all you guys that say "Oh, Don't do it ! They'll break"
Have you ever had one break after YOU heated them, or even heard of a broke spring because it was heated Just as I said, yeah I'm sure one might break if you don't use common sense when you heat it You all have butt holes & opinions, some are just closer to each other than others Thats all I have to say about this subject Last edited by Spray-Bomb; 08-09-2007 at 09:48 PM. |
#23 |
some people dont have extra money laying around..so you gotta make due
#24 |
One man's budget bolt on, is another man's entire budget.
#25 |
Cheap and easy... Cut 1 coil off front springs & find an old pair of late 60's/ early 70's chevelle, monte, cutlass, skylark stock rear springs for the rear. $20 lowered truck...
