Old 08-07-2007, 11:17 PM   #1
xshadow
welding and frame idea
I want to reinforce my frame in a couple of places. I want to be sure it will hold up if I take it off road. I was thinking about welding a plate or angle iron about 12-18” long inside of the frame.
I only have access to a wire welder. Do you think the welds will be strong enough? I have one area with some pits. I want to be on the safe side and reinforce that area. It would probably never give me any problems but better safe than sorry. I may want to take it off road one day. I’m not experienced with welding so any advice would be helpful.
xshadow is offline   Reply With Quote
Old 08-07-2007, 11:57 PM   #2
xshadow
Re: welding and frame idea
My first plan was to place a piece of steel flat against the inside of the ( ] shaped) frame and weld it flat against the inside part of the frame. My other idea was to take a flat piece of steel and weld the inside piece of frame closed.so it looks like [] instead of ] ..a section about one foot long. Like i said I only have access to a wire welder.
Old 08-08-2007, 12:02 AM   #3
1969k10stepside
On mine,I put a 3/8" thick steel plate along the inside of the frame.Not boxing it in,up against the original frame rails.It was cut so it barely fits in there.No space for it to move around in the frame rails up or down.Then,I bolted it on where there was already factory holes in the original frame,and where rivits once held the spring hangers on by removing the rivits,and bolting the hangers on and having the bolts go through the old frame,and the new steel..No welding required...
1969k10stepside is offline   Reply With Quote
Old 08-08-2007, 12:09 AM   #4
xshadow
I was thinking about doing that but my frame has only two holes already in the 12"-18" section. the holes are are about 3" from each other almost side by side. I don't think that will be enough. I would rather not drill new holes and make the frame even weaker. Nor do i want weld on it and make it weak either.
Old 08-08-2007, 12:11 AM   #5
1969k10stepside
Bolt it on using factory holes in the frame.The only holes to be drilled would be ones in the new steel...
Old 08-09-2007, 06:29 PM   #6
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
This is a little out of my realm, but deal with me on this.
If you are off roading, you may want some flex in your frame and boxing/plating it may not help and could hinder the situation. If the frame flexes except at where you beefed it up, there could be stess points where the new steel ends due to it's increased strength.
That's just my $.02, but for curiosity's sake where do you plan on putting this steel?
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
