Old 08-08-2007, 01:05 AM   #1
69chevytruckin
Bleeding brake Question
Fellas i was drivin my truck around and but my foot on the brake pedal and the petal went all the way to the floor, my friend told me there is air in the system and that i need to bleed the brakes, im still new to the classic chevy scene any advice on how to bleed brakes. Any advice or tips is much appreciated.
69chevytruckin is offline   Reply With Quote
Old 08-08-2007, 02:35 AM   #2
DESTRO
Re: Bleeding brake Question
First I would check all your lines to see if it's leaking anywhere.
If it was fine before and all of a sudden started going to the floor,something happened to get the air in there. You will need to fix that before ya bleed'em
You can have someone pump the pedal and hold while you crack the bleeders to let the air out or you can buy a vacuum pump at the store and draw the fluid out. Do yourself a favor and buy a Haynes or Chilton book, It'll explain alot of stuff with pic's
DESTRO is offline   Reply With Quote
Old 08-08-2007, 05:20 AM   #3
cdowns
cdowns's Avatar
sounds like you've got a serious problem a leak in the system/ either leaking at one of the wheel cylinders or calipers or master cylinder// you need a major $$$$$ overhaul of the brake system
this would be a great time to invest the $25 for a factory service manual,available from most board vendors. if you do your own brake job it will save you hundreds of dollars
Old 08-08-2007, 06:53 AM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
It seems that your master cylinder died. But before you start buying parts, check to verify that there are no leaks.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 08-08-2007, 08:39 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Sort of scary! And potentially dangerous... Had that happend to me.
As mentioned above, if no leaks, suspect your master cylinder. Usually air in the brake lines will make them feel spongy and you can quickly pump the pedal to stop... On mine, it was a fairly fast downward plunge! I pumped it a few times and somewhat recovered, but I drove straight to the parts store.
68gmsee is offline   Reply With Quote
Old 08-08-2007, 11:04 AM   #6
mbgmike
Good advice. Bleed your brakes. If problem still exists plug off ports to front and rear brakes on MC using solid plugs Try brakes. if not firm mc leaking. If firm hook up fronts. if firm ok. do the same to rear. if not would be rear. Etc.
mbgmike is offline   Reply With Quote
Old 08-08-2007, 12:29 PM   #7
Premium72
Premium72's Avatar
yup mine did this with no leaks, was the mc. pretty easy fix. good luck be safe.
Premium72 is offline   Reply With Quote
