Old 08-08-2007, 09:39 AM   #1
ohenryoh
Tired of Burning Plug Wires
I have a 72 chevy super with a 350 and hooker headers (block huggers) dropped 3 up front and 4 in the back. I have tried all kind of different plug wires but number 3 is right up against any wire I use. Any suggestions?
ohenryoh is offline   Reply With Quote
Old 08-08-2007, 09:54 AM   #2
falvarez12001
falvarez12001's Avatar
Re: Tired of Burning Plug Wires
I had the same problem with my 71 Longhorn after I put in the long tube headers. I went thru various plugs. A buddy of mine recomended a wire seperator and route them away from the headers. Also you can use a heat sleeve I guess thats what they are called. Got mine from Summit.
Why, Because it's my truck
1972 Chevy Longhorn, Dropped 4-7
1984 Chevy Shortbed custom Deluxe (Daily Driver)
falvarez12001 is offline   Reply With Quote
Old 08-08-2007, 09:59 AM   #3
ohenryoh
I ordered an insulator (sleeve) and I am going to wrap the header. Hope it works.
Old 08-08-2007, 10:37 AM   #4
Ryan Hubbard
A little more expensive fix is to have your headers ceramic coated. I have hooker super comps on my truck and had the same problem and finally had the headers ceramic coated and problem has gone away.
Ryan Hubbard is offline   Reply With Quote
Old 08-08-2007, 10:43 AM   #5
pat
pat's Avatar
My headers are ceramic coated and I just burnt 2 wires. They get really hot really fast, have a couple burns from learning that. I guess Im going to have to buy some wire looms.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 08-08-2007, 10:49 AM   #6
Big White GMC
Big White GMC's Avatar
Get One Of Those Wire Looms That Run The Wires Over The Valve Covers. That Would Help Some.
It's A Beautiful Day In Suburbia !!!!!
Big White GMC is offline   Reply With Quote
Old 08-08-2007, 10:55 AM   #7
ohenryoh
I am right up against the header, with about an 1/8 to a 1/16 inch gap. I will try anthing at this point so off for some looms.
Old 08-08-2007, 10:56 AM   #8
OLDIRON69
The sleeves work well, you can now buy them at most auto parts stores.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-08-2007, 10:56 AM   #9
rophle1
rophle1's Avatar
You can buy a "sleeve" for the wire boots as well as the header. I've never had to use them, but I've heard good things about them.
1968 C10 Stepside
396 bored .030
TH400
rophle1 is offline   Reply With Quote
Old 08-08-2007, 02:29 PM   #10
sleepyboy
'69 Step
I bought the kevlar wire sleeves from Auto Zone. Prepare for sticker shock though. If I remember right, around $50.00.
sleepyboy is offline   Reply With Quote
Old 08-08-2007, 02:50 PM   #11
Musclerodz
The best way to fix it is not to buy the $20 crap plug wire set from Autozone or similar and buy a set of wires from MSD or Taylor. They cost about $80-$100 a set, I have had them lay on the tube and not burn. The insulator is good to like 1200*. In the end it cheaper because you are not continually replacing them.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 08-08-2007, 04:09 PM   #12
OLDIRON69
I did that too on a '71 that I ran hedders on. It is very true! High end wires are worth it. I saw a guy at a race shop hold a torch to one..Can't remember which brand it was though...
05 2500HD 6.0 excab
Old 08-08-2007, 06:56 PM   #13
Ackattack
Ackattack's Avatar
Another thing that I've had to do is get shorter spark plugs. Accel makes some "header" spark plugs that have a shorter body and may get the wire far enough away so that they don't melt.
Ackattack is offline   Reply With Quote
Old 08-08-2007, 07:11 PM   #14
truckgal_1971
truckgal_1971's Avatar
get the ones with the life time replacement warrenty, thats what I had to do saves you a lot of money in the long run. If its that close its hard to say what will work.
1971 GMC Long Step Side
truckgal_1971 is offline   Reply With Quote
Old 08-08-2007, 09:55 PM   #15
70' GMC
HERE.......Somewhere
70' GMC's Avatar
use accel super stock wires and some ties that you use tie up bread or trash for now till you can get more green ready
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 08-08-2007, 10:23 PM   #16
red69ss
Burnouts are therapeutic
red69ss's Avatar
I have block hugger headers (summit brand) with 90 degree taylor wires and aluminum wire seperator (didn't place rear wire on both sides in loom) never had a problem. Will try to post a pic.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 08-09-2007, 07:55 AM   #17
OLDIRON69
Nice looking engine, very clean!
05 2500HD 6.0 excab
Old 08-09-2007, 08:52 AM   #18
olyeller70
Heat sleeves are a part of my solution, the other part is that I buy 25 ft of MSD spark plug wire and some 90 degree boots and make my own wires. Believe it or not it is cheaper than some other solutions and you will be sure that the wires fit.
Thanks,
Mike
olyeller70 is offline   Reply With Quote
Old 08-09-2007, 09:15 AM   #19
Taylor Wires,the best you can do.Most other good wires are made by Taylor and relabled.How do you spell plug wire?T-A-Y-L-O-R.
Old 08-22-2007, 12:57 PM   #20
ohenryoh
I tried wrapping the (hooker block) header and using a plug boot - burnt another plug wire yesterday. I was at a car show and saw that some poor soul had bent his header to gain the necessary clearance. Was considering removing the headers or dinging the header like this fellow did until I found this product on the web today and I am ordering it - I will let you all know how it works. I know it isn't the perfect solution for show vehicles but for those cruisers and daily drivers it might be the trick.
http://www.wrenchrat.com/
Old 08-22-2007, 04:55 PM   #21
Myself
I've got the plug wire sleeving on my S-Blazer and after 40,000 miles no burnt wires yet. It's silicone impregnated woven fiberglass. If you buy Mallory it's pretty expensive. I bought mine from JC WHITNEY. It comes in different colors and is a fraction of the price because there is no name printed on it.
Myself is offline   Reply With Quote
Old 08-22-2007, 05:13 PM   #22
screamin_eagle
screamin_eagle's Avatar
Taylor. Full Metal Jackets. ninety dollars. bought them after I melted trough my fifty dollar blue Taylor's. wish I would have bought these in the first place.
screamin_eagle is offline   Reply With Quote
Old 03-21-2010, 02:03 PM   #23
pheengurs
pheengurs's Avatar
so? did these sparkarms work? I have a problem with my ceramic coated Sanderson cc3 block huggers, burning plug boots like crazy. I've tried the fibre sleeves, tried fabricating metal sheilds, tried hi-temp MSD boots... nothing lasts more than 100 miles... currently the online store for wrenchrat is down, and at the price they're asking it'd be nice to know if the sparkarms work long-term...
1964 K10 shortbox Stepside
383 sbc stroker under vortec heads
sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears
rolling on 33x12x15 tires on 6 lug rims.
pheengurs is offline   Reply With Quote
Old 03-21-2010, 02:05 PM   #24
leddzepp
Moderator
leddzepp's Avatar
This thread is almost 3 years old
ohenryo hasn't logged in on here in over two years.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-21-2010, 02:19 PM   #25
Sinister
Between Trucks...
Sinister's Avatar
Time to carbon date this thread. LOL.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
