Differential fluid change
Ok, I know these trucks (`68) generally use 90 weight gear lube. Couple of questions, though.
its all about the +6 inches
Re: Differential fluid change
You'll have no issues at all going to synthetic other than the cost. That oil will be good dang near forever as long as it does not get contaminated.
I use sealer, the Right Stuff is awsome, but expensive. I get it for free, same with the oils, so I use them. ![]() |
i always like to wash out the insides with kerosene (windex spray bottle) when changing out really old fluid in the rear. i always change to synthetic(mostly royal purple) i just go with the original type gasket held in place with permatex aviation form a gasket// the good thing with royal purple if your running posi is you dont need the posi additive// i run royal purple in my trannies also
brake clean is another goos solvent to clean the rear end out with, it evaporates, leaves no film, and comes in arasol cans.
![]() Join Date: Nov 2006
wash out diff with starting fluid, it cuts the old oil great, has pressure behind it, i use castrol senthetic 85w140 and seal it up with permatex ultra black silicone. jmo
bob
I BELIEVE IN JOHN 3:16 |
I like to run synthetic in the drivetrain, especially the rear end. Synthetic is good stuff but cost too much to use in the engine for me.
Ok. Thanks for the info guys. Should be gett'n after it this weekend.
