Old 08-09-2007, 02:32 AM   #1
oscareltemblo
oscareltemblo's Avatar
Air bags and Drag racing yes/no
I've been thinking about airbags but since I love to Drag race I don't know if shoulf put bags on my truck but I'm also building it for cruising so I need some opinions guys.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 08-09-2007, 10:45 AM   #2
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: Air bags and Drag racing yes/no
Your best bet will be to install the 4 link system with an adjustable lower coil-over mount welded to the axle tube.
This will allow to switch the performance of a coil-over setup to an adjustable air suspension using a Shockwave. You could install a quick release air fitting on the shockwave airline going to the supply valve. So when you want to take it to a track, you can simply unbolt the shockwave, release the line and fitting, and bolt the coil-over back in place.
Now'll you have 2 different working suspensions on the back of your prostreet / protouring truck chassis. If you need parts for the truck let me know. I can help supply you with these items, or help guide you through the project. We're an authorized dealer for Chris Alston's Chassisworks and the images posted above are their products.
Good Luck with the project.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 08-09-2007, 10:32 PM   #3
oscareltemblo
Could I do the coil over while with the trailering arms? I'm interested in this being able to interchange suspension for the track also do you have tubular front supensions that's something I'm planing also. I just saw your page
Old 08-10-2007, 12:01 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Check the rules. Most 12.0 and under classes don't allow bags
dwcsr is offline   Reply With Quote
Old 08-10-2007, 01:04 AM   #5
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
This truck is bagged with shockwaves, and has a Blown Alcohol engine.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-10-2007, 01:36 AM   #6
GWEE
GWEE's Avatar
WOW thats awesome, you have anymore pics of that truck. ive heard the shockwaves are good to sure for raceing but i havent seen one in action yet.
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
Old 08-10-2007, 01:52 AM   #7
oscareltemblo
So I guess it will work and I just thought of something since torque is always carried more to the passenger side rear wheel I can up the pressure on that bag when racing ..
