Old 08-09-2007, 09:04 AM   #1
nartkers
nartkers's Avatar
Blazer tank LWB fuel system help
I am getting ready to install the blazer tank in my 70c10 LWB fleet. Any suggestions as far as fuel delivery system - pump, fuel line, regulator.
I am seriously considering the summit kit
Any feedback would be appreciated
nartkers is offline   Reply With Quote
Old 08-09-2007, 09:13 AM   #2
OLDIRON69
Re: Blazer tank LWB fuel system help
What are your fuel needs? Are you running a electric fuel pump now? I just put a 73-87 Blazer tank in my LWB. I use 3/8" fuel line, or what ever is stock. I ran a hard line from the tank to where the "behind the seat" tank connected on the frame and used rubber fuel line there to make the splice. I bought the sender from a localparts store for $55 and the straps bought them from Lowes. I used the same straps used to tie down mobile homes to the ground when they are set up.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-09-2007, 09:33 AM   #3
cdowns
cdowns's Avatar
you cant do much better than a good old mechanical fuel pump//unless you're running 700-8oohp then it might be time for electric
Old 08-09-2007, 10:23 AM   #4
nartkers
nartkers's Avatar
Will a mechanical pump be good enough to pull the fuel from all the way from the back of the truck?
I don't have any fuel line components at all at this point. I need everything from blazer tank to carb.
I have thought about using an electric pump mounted on the frame near the blazer tank.
Old 08-09-2007, 11:00 AM   #5
cdowns
cdowns's Avatar
suburbans are longer that lwb pickups and they worked fine for 40 years same with motorhomes//sometimes its best if you dont try to overthink things
Old 08-09-2007, 11:07 AM   #6
OLDIRON69
A mechanical pump will be fine. You really want to run steel fuel line from the tank to the fuel pump. I cheated a little at the tank and used a 2' piece of rubber fuel line, flared the steel line and clamped the rubber line to it. I ren it inside the frame rail up to where the factory tank hooked in and did the same thing. You could use braided hose all the way from the tank to the f pump, but it is a little pricey.
05 2500HD 6.0 excab
