Old 08-09-2007, 11:41 AM   #1
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Rearend question???
I have a old question, I have a 72 12 bolt rearend thats on the ground, How can i tell the gear in it. The suburban i yankit from still had the paper card taped to the inside of the glove box door, It said 411 gears but now that im cleaning it up i notice that the rearend has had work done to it somewhere in the past.
What is the simplest way to determen the gear raitio
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-09-2007, 12:03 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Rearend question???
You'll have to take off the diff cover and read the numbers stamped on the ring gear. Divide those #'s into eachother...that's your ratio.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-09-2007, 12:19 PM   #3
Jonboy
Slots go on anything!
You can also rotate the wheel once and count the number of revolutions of the pinion. Pulling the cover to get the numbers is more "correct", but counting hte revoultions of the pinion will get you close.
Old 08-09-2007, 12:40 PM   #4
gulfcoast66
64-66 CHEVY JUNKIE
I got the cover off , where are the numbers located at ? what should i be looking for?
Thanks Chris.
Old 08-09-2007, 12:45 PM   #5
1969k10stepside
On the ring gear in a spot there is a bunch of numbers and there will be some that say 41 11 for example,that being the number of teeth on the ring and pinion
1969k10stepside is offline   Reply With Quote
Old 08-09-2007, 01:18 PM   #6
gulfcoast66
64-66 CHEVY JUNKIE
I really dont know if im reading the correct #'s, but the only #'s that are readable are 3866116 n ? these #'s are stamped on the back side of the ring gear, how do i divide this?
Old 08-09-2007, 01:24 PM   #7
jchav62
1962 C-10
jchav62's Avatar
That's probably the part number or something. The numbers you are looking for should be close to that. Right below if I remember correctly. It should be 4 digits (41 11). Those are the numbers and divide them to get your ratio... 41/11=3.73.
Joseph Chavez
Old 08-09-2007, 01:27 PM   #8
62 short step
62 short step's Avatar
You can't divide those. Count the teeth on the ring gear write it down, then count the teeth on the pinion gear write it down. Now divide those two #'s that should be your ratio.
62 short step is offline   Reply With Quote
Old 08-09-2007, 01:54 PM   #9
killer71
killer71's Avatar
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 08-09-2007, 02:05 PM   #10
gulfcoast66
64-66 CHEVY JUNKIE
Thanks alot everyone,I found somemore #'s 3817778 1141 gm 972. So I divided 41 and 11 and 3.72, Im going with 3.73 gears. where can I find a better highway gear, 3.42, at a decent price?
