Active Member
![]() Join Date: Nov 2002
Driveshaft Slip Joint Seal
The seal for the slip joint on my two piece driveshaft is shot. Where do you get a new seal? I dont think I can replace the seal because I can't get the collar loose. How do you keep the grease in the yoke without a seal?
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
Re: Driveshaft Slip Joint Seal
I have had good luck getting the collars off by spraying them with penetrant, tapping around the collar with a hammer and then use a channel lock pliers to remove them. I have yet had to use heat, but that is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Active Member
Jim
Thanks for the tip. After soaking it for a couple of days and a few gentle taps with the hammar it came right apart. What a great board. Don
Okay, so you got it off...where did you find a new seal?
Active Member
Try LMC truck or Ecklers.
the boat guy
Any driveline shop will have them. How are the slip and stub? If they have lateral play they shouldbe replaced.
LMC, nope. Ecklers, nope. Driveline shops, pretty thin on the ground these days. Just re-used the old seal. It's a driver, not a showpiece.
![]() Join Date: Jun 2009
How about you just go to your local Oreilly's and pick one up for 10.00
![]() http://www.oreillyauto.com/site/c/de...1418&ppt=C0362
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
