Old 08-09-2007, 01:56 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Gauge Cluster Gremlins
I recently put a CST cluster in my truck and did the rewire following GMCPaul's instructions. My turn signals/hazards work great when the headlights are off. When the headlights are on the signals switch sides (when you have the left blinker on the right one blinks and vice versa) Also, the hazards don't flash on the cluster when the headlights are on. This problem is only in the cluster; everything works as it should on the exterior regardless of the headlights being on or off. Thanks for your help.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 08-09-2007, 02:05 PM   #2
cdowns
cdowns's Avatar
Re: Gauge Cluster Gremlins
i like gremlins people give them a bad rap
Old 08-09-2007, 06:29 PM   #3
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
the printed circuits on the back of cluster have been known to cause Gremlins. Check carefully for broken on dirty wires. Grease and oil make good conductors and current can pass thru to another circuit.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 08-09-2007, 07:01 PM   #4
byrd
Union Electrician
byrd's Avatar
check for a bad or broken ground on the printed circuit or, you may need to ground the case of the cluster to your truck for proper operation. The trucks came with a ground clip from the factory and most do not replace it....Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-09-2007, 10:12 PM   #5
dave2953
dave2953's Avatar
Thank you both for your responses. I'll check the board out in the morning.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
