Old 08-09-2007, 02:57 PM   #1
Richard H.
Spanked once
Richard H.'s Avatar
Pixie and Dixie Evicted
Before I noticed the outside of my plenum was smashed in I had already cleaned at this area from the cowl with a vacuum cleaner.
I hate mieces to pieces
Previous damage..
http://67-72chevytrucks.com/vboard/s...d.php?t=248377
Richard H. is offline   Reply With Quote
Old 08-09-2007, 02:58 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Pixie and Dixie Evicted
Man that sucks
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-09-2007, 03:34 PM   #3
mvfd70
mvfd70's Avatar
Hmmm.....Might not be a bad idea for me to take mine apart and check. I'd hate to cut a hole for no reason but then again I'd hate to not and have a bunch of crud in there.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-09-2007, 03:52 PM   #4
70GMCer
70GMCer's Avatar
What is that, about an R-30 insulation value??
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-09-2007, 04:12 PM   #5
Luvlegs
Luvlegs's Avatar
Wonder if that guy ever got his pet badger??? He'd be right at home in there.... and if ever needed, he'd probably kick the truck monkeys a$$.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 08-09-2007, 04:29 PM   #6
Richard H.
Spanked once
Richard H.'s Avatar
In the bottom near the kick panel there is a weep hole big enough for a giants tears if you can get to it or you may have to remove the heater and use a heater hose or something on a vacumm cleaner.
Old 08-09-2007, 04:42 PM   #7
krue
Designated A-hole!
krue's Avatar
Or use an air hose and be patient.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-09-2007, 04:52 PM   #8
Thealien
Thealien's Avatar
Take out the kick panel vent. You can reach inside with a vacuum nozzle (small one) and clean it out. I also used an air hose to move the stuff around so I could get to it all. You can see the back of the vent in the picture.
Open the vent, on the top is a rod that the bottom of the rod is held by a spring clip. Push up on the clip and down on the rod and out comes the vent.
Old 08-09-2007, 08:55 PM   #9
Aarons72s
Here is a suggestion for you guys that do cut the outside of the vent open to clean it out, like richard did. Any truck I do this to I make a patch panel that I put seam sealer on and rivit on so that if it has to be pulled off again it cna be somewhat easily done. Plus I bedliner the inside area like crazy when I do that.
Aarons72s is offline   Reply With Quote
