08-09-2007, 04:40 PM | #1 |
Still Green but learning
AC question
My compressor blew after having someone else convert it to 134. I know I have to flush the system to get the trash out. My plan is to replace the Compressor, Dryer and in line filter.... is there any need to dig out the expansion valve and replace it or should flusing it be enough?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
08-09-2007, 04:51 PM | #2 |
Re: AC question
Here's a discussion. Last post lists a kit for this. I vote to remove the exp.valve and completely clean it out.
http://67-72chevytrucks.com/vboard/a.../t-153157.html
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 08-09-2007 at 04:52 PM. Reason: correct spelling gafe |
08-09-2007, 04:52 PM | #3 |
Re: AC question
dont forget the poa valve also.
I BELIEVE IN JOHN 3:16 |
08-09-2007, 05:02 PM | #4 |
Old member
Re: AC question
I would take the whole system out. It will pay off in the long run. The system needs to have everything flushed and cleaned.
08-09-2007, 05:07 PM | #5 |
Re: AC question
you have to get a poa valve update...if you convert to r134. call oldairproducts.com and they can hook you up and have great tech support.
R.I.P. Killer 71 10/26/07 |
