Exhaust ?
Is the 73/84 exhaust system the same as 67/72 ? Will it fit ?
1997 GMC Sierra Ext 1965 Mustang |
WTB this ad
Re: Exhaust ?
I had a 71 gmc once that had the exhaust from a 67 Impala under it.
Re: Exhaust ?
even if they are both leaf sprung you will have clearance isues with one rear shockbecause 73 and newer have stagered shock mounts. another isue will be at the manifolds. you may get it on but i don't think it will fit properly without some cutting and welding
common sense isn't so common anymore |
Re: Exhaust ?
Never mind the manifolds, I would be using headers. It's just that I always seem to be seeing a lot of exhaust kits for 73 up at decent prices. That's why I'm asking....
67-72 Addict!
Re: Exhaust ?
Run the pipe yourself to the mufflers to save some money and have a local shop mandrel bend over the axle unless you go with the LMC kit others here have liked.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 08-10-2007 at 12:43 PM. |
Re: Exhaust ?
Knew that, but I had a line on a new exhaust system for those year trucks. I know about the LMC one. Thanks, Jim.....
