Easy Does It
speedo cable
I recently unpluged my speedometer cable to take out my instrument cluster. Now I cannot get the cable to go back on, it will only push so far, but not enough to screw the nut to tighten? What am I doing wrong?
Re: speedo cable
I had the same problem, it was like it wasent lineing up. I just kept messing with it and it finally went. I know this dosent really answer your question, but i thought it would help....
Re: speedo cable
I was having that same problem awhile back. I ended up replacing the cable abd it went on with out a problem. I went to napa to get the cable, if you do, get the shorter size.... I now have too much cable under my truck and had to do some creative routing....
1962 Chevy Fleetside
283/TH350 |
Easy Does It
Re: speedo cable
I finally got it back in -I had to twist the small wire back down into the tube,and it slid back on.thanks
