Old 08-09-2007, 09:17 PM   #1
1969k10stepside
Another tranny linkage question
So,I converted my 4sp truck to auto (Didnt want to put the granny 4spd behind my new motor) and got everything I needed but the tranny linkages...So,will auto tranny linkages from a late 70s 4wd work on my '71 4wd with little or no modifications or will I need auto tranny linkages from a 70-72 4wd that had a auto tranny?
1969k10stepside is offline   Reply With Quote
Old 08-09-2007, 09:37 PM   #2
jamie72
jamie72's Avatar
Re: Another tranny linkage question
later model linkages totally different, can be made to `work` but look horrible..i would stick with our era of trucks.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-29-2007, 08:24 PM   #3
1969k10stepside
Ok,bringing this back up...What all differs from a 2wd set and 4wd on the linkages for a th350?
Old 08-29-2007, 09:41 PM   #4
jamie72
jamie72's Avatar
the 4x4 linkage rod is longer and has a curve to it, is you new blazer an auto?? go look at it and compair to a 2wd.
jamie72
member #807
www.antlertalk.com
Old 08-29-2007, 09:45 PM   #5
1969k10stepside
Ok...now I am set...The blazer,going to a 4spd was going to be robbed of the auto linkages for the 71 k10...It turned out to have a B&M shifter installed..I got under there today and guess what they left on? The metal rod from the column that goes down.I guess that is what I needed all along.Now I can use that with my 2wd linkages to work,correct? I must be having some good luck,what's the odds that piece I need is still on it even though they converted it..
I guess tomorrow I'll get the linkages all hooked up.Then install the brake lines and drive it
Old 08-30-2007, 08:57 AM   #6
earl87gta
earl87gta's Avatar
If it doesnt work I would get a locar cable convertion or you could use a universal one like this. http://www.speedwaymotors.com/p/1926...nkage-Kit.html
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-06-2007, 09:49 PM   #7
1969k10stepside
Well,I finally got all my parts gathered up and got the stock linkages hooked up..
