Old 08-09-2007, 11:39 PM   #1
motornutz
rochester 2gv tuning and engine timing help needed
i have a bit of trouble tuning my 2 jet and keeping the truck running. how many screws out (approx) do they (idle screws) need to be. and what about the timing. it wants to die at idle and hesitates upon acceleration. when hot it does not want to start back up (too advanced timing?) i havent put the timing light on it yet. i fixed a vacuum leak but it didnt make much difference. i know the carb is flooding. got any ideas or tuning tips? oh yeah the engine is a stock 1970 350.
motornutz is offline   Reply With Quote
Old 08-10-2007, 07:48 AM   #2
motornutz
Re: rochester 2gv tuning and engine timing help needed
bump...anyone?
Old 08-10-2007, 10:16 AM   #3
Mt Man Chad
Mt Man Chad's Avatar
The Chilton’s manual has a good explanation how to do the tune on a 2 barrel.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 08-10-2007, 02:28 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
When I was building them, years ago, I'd turn the screws in until they just barely bottom out. Then, I'd back them off 2 turns, just for starters.
Be careful when you screw them in....they are softer than the base metal into which you are screwing them. If you aren't careful, you'll cut a groove into the pointed end and that will make any future adjustments very hard to make consistently. If they already have grooves in them, you should get new ones to replace them before you start tuning the carburetor.
Member Nr. 2770
