Old 08-10-2007, 02:02 PM   #1
art.torralba
1970 "heavy Half" trans change question
I've got a 1970 with an inline six and three speed column shift. The rear mounts are on the bell housing. How can I put in a '88 700R4? I have the donor trans, the trans crossmember, flex plate & starter. Do I need to eliminate that bell housing mount and just put the rear crossmember at the rear of the tranny? Will I need to shorten the driveshaft and change the yoke? Or I could just rebuild the column (it sometimes jams between shifts) and keep the three speed, maybe put in a floor shifter (I put in a new clutch).
I plan on keeping the six, but I'm working on fixing all the fuel/vacumn lines, it's got a bad vacumn leak somewhere. The previous owner changed the distributer to an HEI unit, what should the plugs be gapped at?
So many questions, not enough time (and money).
art.torralba is offline   Reply With Quote
