Old 08-10-2007, 07:39 PM   #1
68_Steps
68_Steps's Avatar
Unhappy having issues...
So I had a U-bolt on my front lower control arm give out last friday. I've gone through two different companies to order a replacement, both are apparently 9/16" in diameter and are supposedly OEM parts, but wont fit through the bolt holes on the frame. I've been told they used these bolts from 1967-1991 but I just cant figure out why It doesn't fit my truck... anyone have any ideas?? Thanks in advance. ~Craig
68_Steps is offline   Reply With Quote
Old 08-10-2007, 07:46 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: having issues...
The 9/16" u-bolts are the ones you want... now it's just time to "upgrade" the mounting holes! Get your trusty 1/2" drill out and slap in a 9/16" drill bit. Drill em out and slide in the beefy u-bolts... away you go!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-10-2007, 09:12 PM   #3
SCOTI
SCOTI's Avatar
The 9/16" u-bolts are what was used w/disc brakes. The smaller 1/2" u-bolts were used on drum brake equipped trucks.
Upgrading is as simple as drilling the holes to the larger size.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-10-2007, 09:22 PM   #4
jasonb72
PorterBuilt Man Crush
I had the same prob with my ubolts from Totally stainless they had 1 pair out of the two pair that came with the bolt kit that did not have the correct opening from outer thread to outer thread. Not sure if it the same prob you are having.
The 72 will live again
jasonb72 is offline   Reply With Quote
