Tightening down the bolt on harmonic balancer
Whats a good way to tighten down the bolt on the balancer? The engine is in the truck.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
its all about the +6 inches
Re: Tightening down the bolt on harmonic balancer
turning it clockwise.
I use a 2x4 and a BFH to drive it on, then torque the bolt down.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
River life......
I used the installer after the 2x4 trick went awry the last time. As for the bolt, try a strap wrench on the balancer and tq the bolt. Or impact gun.
be careful ... they WILL strip ... don't ask me how i know ...
buy or make an installer !! driving it on with a hammer will only destroy the main bearings . i made one from welding a damper bolt to a piece of 3/4" threaded rod . lube up a stack of washers and take your time . as for the torque on the bolt , never use and ipact to install it , its fine threaded and you can easily strip it out .only tighten it when you know the balkancer is fully seated .most stock bolts are not very long and only grab a few to several threads especialy with aftermarket pulleys .with the pulley bolted, take a pick or scribe ,feel the threads and measure to get the longest bolt you can use . places like napa , ace or fastenal can get you the grade 8 fine threaded 7/16" bolt . ive gained up to 1/4" - 3/8" of threads .ived saved a couple motors where the threads have been stripped out and the crank was thought to be ruined .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car Last edited by 66skylarkpost; 08-11-2007 at 12:04 AM. |
Also, careful......they WILL break off....and don't ask ME how I know......
1997 GMC Sierra Ext 1965 Mustang |
speaking of stripped.....lol found out mine is anyone got any suggestions on the next size up tap and bolt I should use?
what's the torque spec on the bolt?
